Dimmer help please | on ElectriciansForums
Discuss Dimmer help please in the Talk Electrician area at ElectriciansForums.net
DanUK
Hello! I have just had some new lighting installed and when lowly dimmed some of the bulbs seem to flicker.
The bulbs used are: 10x LAP GU10 LED Lamp 330Lm 956Cd 5W | Light Bulbs | Screwfix.com (6 on one gang, 4 on the other)
The dimmer switch the electrician used is: LAP 2-Gang 2-Way Push Dimmer Switch 400W/250VA Polished Chrome | Switches & Sockets | Screwfix.com
Is there anything obvious here as to why that would happen? Is the load too low for the switch!?
Thank you!
i'dsa y the load mat bre too small. try replacing 1 LED with a halogen lamp. it that cures it, then that;s the problem. also, is the dimmer trailing edge?
That dimmer shows a minimum load of 60W, you have 20 & 30W on the two dimmers so yes it's too low.
cant dim led lamps
Not always true. The lamps in questions are stated to be dimmable. There can be compatibility issues though with certain combinations of lamp and dimmer.
Personally my opinion of LAP is what it rhymes with, CRAP.
try a V-Pro led dimmer module instead and BELL 5w or 6w dimmable lamps at approx ÂŁ5.80 each. The dimmer has a little adjuster so that you can set the min level.
i only fit quality gear and never have problems.
the alternative is to rip the can and lamp out and fit JCC FGLED 10 downlights as they are top notch and you can dim them to a point of virtually off.
everyone knocks LAP accessories, but i've seen worse. for the price, they're not too bad and it's a p-o-p to nip the nearest screwfux to swap any duff gear.
Thanks for all the replies!
yes, the electrician supplied it all. It flickers but very subtly.
I'm no expert I'm afraid so not sure if it's 'trailing edge' etc. Would rather not replace the bulbs as they're the same throughout my entire flat.
As one gang of the dimmer controls 6 of these, the other 4, what should I be looking for in the dimmer? I don't always have both sides on, so do I need one to be able to cope with the lowest load (which would be 20w)?
Thank you for all the help. Really appreciate it.
best advice is to get the electrician back to replace the dimmer/s with ones that don't cause the problem.
Reply to Dimmer help please in the Talk Electrician area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
