Dimmer in one room dims the lights in another room... | on ElectriciansForums
Discuss Dimmer in one room dims the lights in another room... in the DIY Electrical Advice area at ElectriciansForums.net
A
AsaG
Hello,
First post here, hoping that someone can help.
Moved into a 1935 house that has 3 bedrooms upstairs, all with Halogen spotlights in.
They all have dimmer switches on the walls, problem is that we have noticed - If I am in the Master Bed and the Wife goes to either the Box Room or Spare Bedroom and turns that dimmer - it will not only control the light in the room she is in, but also in the room I am in.
Weird thing is that this happens sometimes, but not all the time... I am very confused - is there something up with the way it has been wired? or are the connections to the dimmers themselves wrong?
Im not an electrician but I don't mind rewiring a light switch if needs be.
Thanks in advance for your advice...
Sounds like someone has cocked a two way circuit up if it only happens sometimes and not others.
I have had to put this right in the past when someone has attempted to convert a two way to a one way and got it wrong, usually when they try to remove the old pulls switch above the bed arrangement.
You end up with a switch which switches the feed to other lights in one position and it does something else in another position.
If it is a botched two way then you fix it by finding the incorrect connection and connecting it correctly.
I would expect to find a central joint box in the loft somewhere, chances are the bad connection has been done there.
This is only a hunch though based on previous experience, I may be completely off the mark here.
Reply to Dimmer in one room dims the lights in another room... in the DIY Electrical Advice area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
looks like the OP has disappeared which is a shame, would be nice to get to the bottom of this.
