Dimmer keeps blowing | Page 2 | on ElectriciansForums
Discuss Dimmer keeps blowing in the UK Electrical Forum area at ElectriciansForums.net
L
liamruairi
Any advice is much appreciated. I have a new light fitted, 10 x E27 40watt filament bulbs. Its this one: 10 Lights - Edison Chandelier Pendant Lamp Ceiling Light Bulbs Remote Control | eBay
I have now fitted 5 dimmer switches and not found one that works. Leading edge dimmers buzz really loud and trailing edge ones keep blowing. I bought a 400w varilight remote dimmer which worked lovely, then i turned it on once (full brighness) and it blew. I thought i needed an over-capacity dimmer so bought the same but 600w version (max light fixture watt is 400 - 10x 40w bulbs) and same thing happpened. Worked dimmed for few hours, turned off, then on again at full brightness and it blew. What am i doing wrong? Do i need an even bigger capacity like a 1000w dimmer?
thanks for advice!
liam
Hang on a minute. The fitting the OP linked to says it includes a remote control, i.e. there is a receiver / control unit in the fitting that probably isn't designed to operate on a dimmer, unless the instructions say otherwise. I bet it contains a capacitive dropper to power its own electronics and that is what is causing the dimmers to buzz / fail rather than the lamps themselves. A larger dimmer might survive, but the control unit in the fitting might fail too.
E2A: if that is the problem, it could be bypassed, at the cost of invalidating the fitting's safety approval and warranty.
Yes it does have a remote control but it just turns all lights on or off, or 5 of the lights on or off at a time. There isnt a dimmer button on the control. With all the dimmers ive tried except from the varilight the fitting (im guessing the reciever in the rose) buzzed so loudly. Any work around?
Sounds like it is not designed to be used on a dimmer switch as it needs a permanent live so you can use the remote control.
As per my post above, the remote receiver can probably be bypassed. Although you are not using it, the electronics are still in circuit and incompatible with the chopped waveform of a dimmed supply. What is this transformer you mention? Are they not 230V lamps?
That's handy, a self-contained module. So it looks like all the lines are commoned in one crimp to a black lead, and the neutrals in two sets to the blue and white. So it would be the work of minutes to connect those leads to the corresponding incoming terminals and get rid of the module completely.
How do i do this then, any diagrams anywhere online? Is it as simple as joining black to black in a terminal block and the white and blue to red incoming? The seller just emailed me a pdf of how to remove receiver but its a large zip so will have to wait till later to unzip it and have a look. If i did connect them all straight to the mains with no reciever am i right i. Thinking i wouldnt need a transformer and a dimmer would work (should work!) fine?
Unzip & read that PDF first THEN start asking questions - if you need to.
It's pointless jumping the gun!!
Ok so the 'pdf' was actuqlly a zip file with 35 pictures of the assembly process if the remote unit was to be removed. Attached here is one of the final pictures along with a picture of the reciever unit. Looks fairly straight forward, all lights are tethered to one of 2 brown/blue which would then tie in the feed in at the ceiling rose, correct? Then all I have to do is connect a normal dimmer switch at the wall and it should work?
http://tinypic.com/r/214wnxw/8
http://tinypic.com/r/1zybfno/8
Reply to Dimmer keeps blowing in the UK Electrical Forum area at ElectriciansForums.net
