Dimmer Switch- 3 gang - 250w is this for each gang? | on ElectriciansForums
Discuss Dimmer Switch- 3 gang - 250w is this for each gang? in the Talk Electrician area at ElectriciansForums.net
C
cairns
Hi there,
Just wondering if a switch (250w rating 3 gang dimmer switch), whether the 250w rating if for each gang, or all 3 gangs?
Cheers.
John
250w/gang. deffo. i.e.you have 3 x 250watt dimmer switches. pretty obvious really. what use is a 80and a bit watt dimmer?????
What a rude reply!
My kitchen only has 1 working GU10, my understairs cupboard has 1 downlighter..................................
dimmable carp pond lights (Anyone heard from Durham the firestarter?)
All to do with saving energy
Should we start a stupidest question for 2011 competition?
What a rude reply!
did not mean to be rude, cbw, just straightforward and to the point.
ok cheers, yeah see your point. I'm only really used to lutron and ilight systems, havent done much old fashioned stuff like you.
so it would not be advisable to have you repair my valve wireless set?????
p.s.where is the planet lutron????
My worry is someone asking such a simplistic question could be confused with me.
A look at the spec sheet would have answered the question before it was asked!
Reply to Dimmer Switch- 3 gang - 250w is this for each gang? in the Talk Electrician area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
