dimmer switch and fan.... | on ElectriciansForums
Discuss dimmer switch and fan.... in the UK Electrical Forum area at ElectriciansForums.net
Dave_
Alright lads....
Client wants to put the bathroom lights on a dimmer (4 x 6w LEDs). Also fitting a vent axia VA100 XHT fan... May there be an issue with the voltage fluctuating on the switch live if the lights were dim... Ie the fan may cut out or dimmer/ fan may die? Anyone have experience of this??
far better. who needs a fan when just going for a pee, middle of night.
- - - Updated - - -
Reply to dimmer switch and fan.... in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
I want to fit a Trailing Edge Pull Cord Dimmer Switch in the bathroom with 2 dimmable LED bulbs. LED dimming range is 5-100w for the switch. Light...
