Maximum Zs Value Exceeded | on ElectriciansForums
Discuss Maximum Zs Value Exceeded in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Hi
I have recently done some testing on an installation. A submain is fed from a B50 mcb and has a zs of 1.10ohms. The maximum for this is 0.87. The cable supplying the submain is a 25mm 2 core swa with the armourings used as the cpc and is roughly a 70m run. Both glands and earth leads have been checked and are okay.
Would it be viable to fit a 300ma rcd to protect this circuit as the disconnection time cannot be achieved. The problem I have is the building supplied by this has two large heaters and a number of vacuums and there is an earth leakage of around 150ma.
Each circuit in the submain has individual 30ma protection.
Upgrading the cable/running a separate earth alongside the swa would not be possible due to the nature of site.
Hi
Yes an upfront time delayed rcd is an option.
What is the Ze ?
How many Rcd circuits are there being supplied by this sub main. ?
Reply to Maximum Zs Value Exceeded in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
