F
FOBG45ER
This seems to be an ongoing problem with my dimmer switch connected to a four candle centre light. I had problems with cheap switches blowing and follwoing advice from this forum I bought a more expensive Click Deco 1 Gang 2 Way 400W/VA Dimmer Switch. This has been working fine for a number of weeks until now. Two of the bulbs blew in quick succession and now the dimmer is stuck on full brightness whichever way the switch is turned. The bulbs were 40w each so wasn't over or underloaded accroding to my calculations.
Has this switch been put out of action? Any ideas if there might be an underlying problem with the electrics causing the bulbs to blow and does this cause dimmers to go wrong in this way? The switch was fitted by an electrician and he checked the light fitting at the same time with no problems found.
Any suggestions?
Any suggestions?
