Dimmer Switch Problem | on ElectriciansForums
Discuss Dimmer Switch Problem in the UK Electrical Forum area at ElectriciansForums.net
Simon_G
I've been having problems with a couple of dimmer switches in use with dimmable energy saving bulbs that I'm led to believe is due to the switches being under loaded. Would something like this 2 Way 120w LEDlite LED & Low Load Dimmer Switch - Module be a suitable replacement if I were to swap the current dimer modules for these?
Thanks for any help or advice.
Cheers,
Simon
Reply to Dimmer Switch Problem in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
Thanks for your feedback. Its reassuring to know your experience suggests space won't be an issue. I requested 47mm backboxes for switches when...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
