Dimmer switch & Ventilation fan | on ElectriciansForums
Discuss Dimmer switch & Ventilation fan in the Australia area at ElectriciansForums.net
In relation to the dimmer switch operating the ventilation fan, there are certain perameters which must be identified first, such as -- is it a multi-speed fan, is the wattage of the dimmer sufficient enough for the motor size. There does not seem to be sufficient enough information to answer the question properly.
In a fan with a timer over-run the switch live is only used to trigger the fan. The fan itself is powered by the permanent live so that it keeps running after the light is switched off.
Reply to Dimmer switch & Ventilation fan in the Australia area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
