Hi. Buying light fittings was easy last time I had to do it (years ago). Now renovating and want all lights on dimmers. Electrician has wired first fix already. Now I need to choose the right light fittings/bulbs/types of dimmer switches.
I'll have a mixture of recessed spots, wall lights and a few pendants throughout the house.
Could you tell me, can you generally put any type of bulb in any light fitting - ie halogen, CFL and LED (to the max wattage advised)? Or do different light fittings only work with specific types of bulbs?
Also, are all light fittings dimmable providing you put dimmable bulbs in with a compatible type of dimmer switch?
I prefer halogen bulbs (for the colour) and will sacrifice the energy cost savings to get this. Are all halogen's dimmable or do you have to buy 'dimmable halogens'? Which is the correct type of dimmer switch for halogens? Are both trailing-edge and leading-edge dimmer switches suitable?
How about CFLs - if you buy dimmable CFLs, should you buy trailing or leading edge dimmer switches?
And LEDs - if you buy dimmable LEDs, should you buy trailing or leading edge dimmer switches?
And finally if you are running a mixture of LED and/or CFL and/or Halogen bulbs in multiple fittings off one dimmer switch, which dimmer switch should you use.
Thanks so much - this is driving me mad!
- TL;DR
- dimmers - which type of switch is compatible with which type of bulb? Can all light fittings be dimmable if you use a dimmable bulb and a compatible dimmer switch?
