Dimming LED's | on ElectriciansForums
Discuss Dimming LED's in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
I used the dimmable electronic transformer 35-105W (see picture) with a 12W dimmable ar111 LED and it dims ok. I thought that the minimum load had to be 35W?
  • [ElectriciansForums.net] Dimming LED's
@hawk, It is not necessary that the minimum load should be 35W as minimum load is not an issue but the maximum load should not exceed the 105W otherwise it will draw more current and it will damage the transformer. For 12W it is perfectly safe as it will draw less current and no harm from less current.
Minimum current requirement is there for some conditions. For a basic voltage step-up or step-down transformer, there is no such requirement but this requirement is placed for advanced power supply circuits where load maintenance is a critical parameter. It won’t go haywire but the circuit might not be able to regulate properly and there might be some noise if you don’t meet the minimum load requirements.
Reply to Dimming LED's in the UK Electrical Forum area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
