Dimplex XL18N storage heater | on ElectriciansForums
Discuss Dimplex XL18N storage heater in the UK Electrical Forum area at ElectriciansForums.net
Livingston
Hi quick question guys,
I was called out to a storage heater not working, turned out the thermal cut off had tripped, customer doesn't dry any clothes on it and I believe this to be true, I've had to return to it again, I've cleaned it out completely to make sure it wasn't a build up of dust etc, and re set again, it seems to work for a month then trips again, tested the elements they were fine, about 23 ohms if I remember correctly which is what they roughly should be, does anyone know if it would be best to replace the thermal cut out switch or have any other ideas, getting annoying for the customer and myself now, I don't deal with storage heating too often. Thanks in advance!
If the cutout is tripping and everything tests out fine you are looking at either a weak cutout or a thermostat not switching off. If I remember rightly the cutout and input stat are an all in one unit now so both get replaced at the same time anyway.
Reply to Dimplex XL18N storage heater in the UK Electrical Forum area at ElectriciansForums.net
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
Fantastic thanks Freddo that last photo confirms all your suggestions so I’ll get back over and remove the links and test. Thanks again!
