Din Rail Connectors | on ElectriciansForums
Discuss Din Rail Connectors in the Australia area at ElectriciansForums.net
L
leolec
Had a job this week where I wanted to extend three 35A rings - wanted to use din rail connectors so down the the local wholesaler who looked at me as if I had two heads.............
so on looking these up on the net is this what I should be using?
[ElectriciansForums.net] Din Rail Connectors
given the correct jxb rating I assume I can use them to extend any curcuit?
Does anyone have any recommendations on good enclosures for them?
i did a job CDU upgrade a while ago had to lower the board as it was ceiling height and a very frail elderly lady this was before i discovered wago's , it cost more for the din rail connectors than it did for the board ,and they are so quick saves time and money , used them on the last job i did extended legs in plastic trunking makes life so easy
Reply to Din Rail Connectors in the Australia area at ElectriciansForums.net
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
