View the thread, titled "Din Rail Electric Meter" which is posted in UK Electrical Forum on Electricians Forums.
Hi,
I need to put a small enclosure in for someone for an electric car charge point, needs RCD, 32A MCB and an electric meter.
Has anyone used any din rail mounted meters, single phase 32A 1 module that they can recommend that are cheap?
Thanks for the PM about this, unfortunately I am not the one installing the charge point, I am however on the Government Approved Installer list and went through the 3 month rigmarole to get approved.
I have only been asked to put a suitable 32A metered supply in near the intake so that they can connect a 6mm circuit to it.
Personally I would just put a 6mm circuit in to a Rolec unit with built in meter, but they are not installing a rolec unit.
The charger unit that is being installed by the customer......would that not a have a meter by the manufacture within?
Reply to the thread, titled "Din Rail Electric Meter" which is posted in UK Electrical Forum on Electricians Forums.
