View the thread, titled "din rail timer, light switch override for outside lights" which is posted in Australia on Electricians Forums.
I
ianbrookes
I am looking for honest advice. I am a newbie but fully qualified domestic installer but have never done this install before.
I have an MK timer switch MK 5731s (din rail mount) an MCB for outside lighting (with RCD protection).
for cables I have a three core + earth running from the CU to the switch and an 1.5mm SWA 3 core running from the switch to the lighting transformer.
the customer wants the switch to override the time when required.
I am looking for wiring advice please.
Originally Posted by ianbrookes
override for both on and off is required..
Then as others have said you will need a 3 position switch, at the very least.
Pos 1 = timed L feed
Pos 2 = No feed
Pos 3 = Perm. L feed
N= Common to load (not switched)
Reply to the thread, titled "din rail timer, light switch override for outside lights" which is posted in Australia on Electricians Forums.
