Disconnecting circuit in CU - best practice? | Page 3 | on ElectriciansForums
Discuss Disconnecting circuit in CU - best practice? in the UK Electrical Forum area at ElectriciansForums.net
Deuce
Stamford
Hi all,
I'm in the process of renovating the bathroom. There is an electric shower I have removed and won't replace. The cable is not practical to remove.
To make this redundant circuit safe, what is the best way to cap off in the CU? I plan to label it too, both in the CU and at the other end in the loft. This end originally ran to the isolator in the bathroom, which is now removed. The final couple metres cable from the isolator to where the shower was, is deep in the wall so can this just be cut back and buried?
Someone else said to terminate the old cable to earth bus in the CU but I've never actually seen that done before, having looked at many CUs in older properties with redundant circuits..
Looks like a neat job @westward10
I've not fitted a Schneider consumer unit in years/possibly only before Schneider purchased the original companies. Anyhow, are the line and neutral connections really that way around? Every consumer unit I've fitted with the main switch on the left had line on the left and neutral on the right.
Cheers Matt, yes the line busbar from the bottom of the isolator is set and passes across the neutral, odd set up but is correct. Not something I normally fit but they obtained the unit.
they are made like that. the L busbar is cranked behind the N terminal.seems daft, but that's how it is.
Reply to Disconnecting circuit in CU - best practice? in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
