Discovered exposed wires | on ElectriciansForums
Discuss Discovered exposed wires in the DIY Electrical Advice area at ElectriciansForums.net
anasttin
Bacchus Marsh
I moved an old cabinet the prior owner left in my garage, and found some exposed wires behind it.
Can anyone tell me what it might be based on the picture and if I can just turn off power at the meter and terminate it with electrical tape?
I live in Victoria, Australia if that helps.
Thanks so much.
[ElectriciansForums.net] Discovered exposed wires
Reply to Discovered exposed wires in the DIY Electrical Advice area at ElectriciansForums.net
Live wires under floorboards? any years ago, when my daughter was just a crawling stage, we were having a new carpet fitted in an upstairs room...
Even if it’s says that the neutral is bonded to the generator, you still are required to install a ground wire from the generator to the transfer...
