discrepancy from a scam | on ElectriciansForums
Discuss discrepancy from a scam in the UK Electrical Forum area at ElectriciansForums.net
sedgy34
so if your nic registered and you change a DB you have to do tests ze r1r2 on final circuits and zs,s etc put in the box wired by others
and
if your napit registered ive been told you do ze & zs,s on final circuits only as you havnt wired the property
so if someone wires there house DIY and they call you in to change the DB you change the DB and put in box Wired by others as you have to notify the DB change the installation gets a Part p certificate
your thoughts on this as my half day scam is getting closer and i want to put it in as a question!!
When you install the CU, you are only certifying the installation of the CU.
If there are and installation faults in the installation labelling, connections, routing, sizing etc, you put a disclaimer as system buried in the building fabric not inspected.
well the notification will only include the cu done by the spark , not the rewire done by the diy'er.
so the diy'er wont be getting his own work notified by the back door.
is this what you mean ?
The EIC has a box saying what part of the installation this certificate covers, so just write DB change only.
When I register jobs with Elecsa they ask for the certificate number. So there should be a audit trail for the registation and the Part P notification.
Sent from my GT-I9300 using Tapatalk 2
Yes they will. But if problems arise later on and they follow it up and realise that the Part P cert doesn't cover what Mr DIY then there could be repercussions to follow.
in the scenario mentioned it would take years for anyone to notice, by this time whos bothered!!!!
Why would it. Yes here is the Part P certificate and here is the EIC that covers the works done. If it isn't notified on the cert then it isn't covered.
Biff, what's changing?
Usually a EICR should be carried out before consumer unit change, more often than not, missed! :) Just saying lol
Not confirmed yet but have been proposed.....
Fewer types of job that need to be notified.
Cheaper council fees for sparks that arent in a scheme but are qualified.
Third party inspections / certs for diy work.
Will be decided at the end of year.
Reply to discrepancy from a scam in the UK Electrical Forum area at ElectriciansForums.net
You need a CT clamp at main tails, it depends on the rules where you are - you used to be allowed wireliss ones (such as MyEnergi Harvi), these...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
