discrepancy from a scam
sedgy34
so if your nic registered and you change a DB you have to do tests ze r1r2 on final circuits and zs,s etc put in the box wired by others
and
if your napit registered ive been told you do ze & zs,s on final circuits only as you havnt wired the property
so if someone wires there house DIY and they call you in to change the DB you change the DB and put in box Wired by others as you have to notify the DB change the installation gets a Part p certificate
your thoughts on this as my half day scam is getting closer and i want to put it in as a question!!
agreed but the house holder still gets a part p cert because of the DB change no oone is non the wiser so it just clarifies part p is taking the PEE
Not really.
The certificate the householder receives from the electrician's scheme provider quotes the certificate no. of that issued by the electrician which states the extent of the work carried out so it just clarifies the work the signatory electrician has done.
I think you are absolutely right. We know that the EIC covers the CU change only, but joe public gets a piece of paper to wave around and tells everyone "I have an installation certificate so all is well". LBC look at said piece of paper and say "Ooo, an installation certificate. That means all is well."
I was speaking to a plumber the other day who was in a property doing some pipework in the loft while a sparky was changing the CU. New board was fitted and all tests came back hunky-dory, but just before sparky left the plumber noticed a mass of cables in the loft which he didn't like the look of. He called the sparky up and it transpired that there were several connections up there in terminal block with several bare line conductors!
You can't blame the householder though for thinking that an EIC means that the whole installation is tested and safe, when the LBC often don't know the first thing about electrics and certification.
But there is only so much we can do. We all know a MOT means nothing in the safety of the car. As long as we fill in the relevant certificates correctly and you keep a copy of them then you have carried out as much legally as you can. It is upto the customer to read and understand the certiifcate, or at least contact the contractor to get any clarification if theu do not understand it properly.
Sent from my GT-I9300 using Tapatalk 2
Guitarist your playing my tune!!! This is exactly what I'm on about
Both the EIC and the Part P cert will say upgrade or replacement of CU on them so it should be pretty plain to anyone who looks closley what work has been done by a competant person. The confusion comes when the house is sold or whatever and the householder is waving a bit of paper saying everything is covered and no-one looks closer and takes their word for it.
I recently got asked to fit a new twin socket in a friends garage the day after they moved in. She is a conveyancer so is pretty switched on with house sales. She got told that the house had all been tested and passed with regards to electrical safety.
I found the whole house was cross polarity due to a plate screw nicking the live in a socket. No RCD or MCB tripping as when the CU had been changed the main earth had been lost back down the wall cavity!!!!!! Don't ask me how it caused the cross polarity but all was ok once I'd installed a new 16mm main earth and sorted the socket abortion. It's plain there is loads of DIY intalled. The part p cert turned out to be for some heating controls in the kitchen.........
Having just briefly looked at thay document it looks loke Part P was introduced to make us work to the relevant BS7671. Why not just make that a legal document and do away with alk the beuacracy.
Test certificates and testing has been in since elektrickery was invented or near as, how many sparks before Part P actually tested or owned a meter AND supplied a certificate?
To be perfectly honest with you, I have rarely come across a certificate since the introduction of Part P.... Went to a customer 2 weeks ago.
Me : Before I start, can I see the certificate for the consumer unit that was installed last year please.
Customer : Oh that. Well, he said I could have one, but at the end of the job he said he'd post it. I never received one. I don't think he really knew what he was doing!
You've hit the nail on the head. To a non-electrician, any piece of paper with electrical readings on it is a certificate which says everything is tested and safe. We need some serious education for our public and council officials!
Agreed there is no one educating the general public about the part p and the only people coining it in is the scams and labc if you put in £50 on your price towards scam registration labc notifiable works etc you don't get the work Cyril down the pub takes over and his payment peanuts for a few pints of guinness
