showerproblems
Discuss Dishwasher stopped working, so opened it up... in the Electrical Appliances Forum area at ElectriciansForums.net
Cheers,The white thing is just a terminal, it is just there to join the wires to the switch.
I suspect it was the connector loose (or the idc connection with the wire?), not the microswitch.Also, do you you reckon it is because the microswitch failed that caused the burning?
Brilliant -cheers for the (much needed) infoYou won't find that assembly with the two terminals in the plastic cage you'll have to use two normal separate crimp terminals. You need 6.3mm female 'faston' insulated crimp terminals. Not sure the best place in the UK to get them, maybe try Farnell if they're still around. Pick up a cheapy crimper wherever you get the terminals from.
Could it be the reddy brown terminal that the wires connect to (on the door catch) ? YesUpdate- got the wires stripped and crimp connected- but still no joy.
i could by a new door catch and try that, or even a new terminal board (for £30)- though that seems undamaged.
Dishwasher has been great and I am loathe to replace it due to some easily fixable electrical fault.
Not sure if its worth the effort or not now.
Ah, ok- great info . Will get a new microswitch off ebay (they are less than a tenner) today and replace that also.Could it be the reddy brown terminal that the wires connect to (on the door catch) ? Yes
I was under the impression you were going to replace the microswitch as well (Your post #4).
By making my comment about maybe it was a loose connector being the problem, I didn't mean to put you off replacing the microswitch (the reddy-brown terminal)
Suggest that is the next step (or replace the whole catch).
You can check the switch with a meter, or connect those wires directly together (and insulate it) then turn the machine on and see if it works, but obviously it won't stop when you open the door, so that might be a problem
Reply to Dishwasher stopped working, so opened it up... in the Electrical Appliances Forum area at ElectriciansForums.net
