Dishwasher timer issue | on ElectriciansForums
Discuss Dishwasher timer issue in the Electrical Appliances Forum area at ElectriciansForums.net
S
Simon
Hi,
We have a dishwasher that when it starts then there comes a pause for about 6-7 minutes before it starts working. It ends each washing program with satisfactory results.
I can't remember as if it has always had such a pause or not, thats why I wanted to ask you who have the knowledge if it is normal for a dishwasher to have such a pause, or it could be a sign of eventually its timer need to get replaced.
I have looked at the wires around the timer and all seems fine, no sign of corrosion or damage.
Thanks in advance
I am not sure, should it generally take 6-7 minutes to heat up the water?
If you're in a hard water area, then it's entirely possible that the heating element has furred up over a period of time. This could slow down the water heating time as the heat transfer becomes less efficient, try running a good de scaling solution through the machine. Once you've done that, run a solution of 1 Jiff lemon & 2 table spoons of White vinegar through on the hottest wash.
"Washing machines live longer with Calgon" - just saying.
Do you hear water go in then the long pause? If so then water getting up to temp like being said.
Reply to Dishwasher timer issue in the Electrical Appliances Forum area at ElectriciansForums.net
Sorry for the late reply but if you don’t have it working garbage disposals are supposed to have their own circuit but I don’t know how old your...
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
