When the dish washer is switched on the rcd trips after 5 mins could it be the heating element broken down in the dishwsher hence going to earth ?? any clues any one
Discuss dishwasher trips rcd in the Electrical Appliances Forum area at ElectriciansForums.net
heating elements on cookers/toaster/washer dryers etc are all Hygroscopy (have the abilty to attract moisture from the surrounding environment. This get worse the longer they are stood without been used. This causes nuisance tripping. Earth leakage tester is the easiest way to check.
Before opening the dishwasher up see if you have any user instructions as these usually tell you the cycle info of the dishwasher, if your dishwasher has a cold rinse first then it does (as mentioned by others) point to the pump or heating elements but if it fills the water first and heats it up its more likely to be the pump as you say it takes five mins before it trips its just a matter of running it a few times to see if you can pinpoint the cycle stage, better still if your dishwasher has a cold rinse only option on itWhen the dish washer is switched on the rcd trips after 5 mins could it be the heating element broken down in the dishwsher hence going to earth ?? any clues any one
Reply to dishwasher trips rcd in the Electrical Appliances Forum area at ElectriciansForums.net
