SRE
Is everyone installing 500mm from the edge now? We try to but we're going to 300mm if we need to - just wondered what everyone else is doing??
Discuss Distance from Roof Edge in the Green Lounge (Access Only) area at ElectriciansForums.net
It doesn't say you can't install in those zones, just effectively that if you don't bother doing any sort of assessment, then you should be using 500mm as your edge zone to avoid any potential of going wrong.V3 of MIS blah de blah that came out in April .... doing my head in everytime I looked at it so I stopped looking. When I see some of the appalling installations that others get away with I'm not sure what's to be gained by sticking to the rules when others blatantly ignore them but get loads of work!
- - - Updated - - -
Same as us then.
Reply to Distance from Roof Edge in the Green Lounge (Access Only) area at ElectriciansForums.net
