Distribution boards | on ElectriciansForums
Discuss Distribution boards in the Australia area at ElectriciansForums.net
A
ahop
Hi all
I am doing a commercial install, rewiring a village hall, in this hall we have 2 x rings, 4 x lighting circuits, 1 x immersion heater, then it is 6 x convector heaters and 4 x infra red heaters. All heaters are on their own radial circuit and are to be controlled 2 x timer switches via contactors, my query is the distribution boards.
It is a 3 phase supply so i was wondering what is best as all circuits are single phase, 1- putting in 3 x 10 way db's with RCD main switches this seperating circuits onto different RCD's and putting the 2 contactors inside the board or 2- 1 x 3 phase board with RCBO's on all circuits, obviously trying to keep costs down but do you guys prefer any of the options above or do you have any better ideas.
Many thanks
3ph db RCBOs as required no need for RCD jobs a goodun Just remember and take care labeling appliances on different phases with in touch of eachother and watch loading on each phase ( never perfect but as near as you can get
an 8 way 3 phase board used as 24 way single phase, room for future expansion. RCBOs where necessary, MCBs on heaters and lights ( as long as surface cabling)
Reply to Distribution boards in the Australia area at ElectriciansForums.net
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
