Distribution | on ElectriciansForums
Discuss Distribution in the UK Electrical Forum area at ElectriciansForums.net
scotland
Hi guys, just wondering if anyone has an alternative way of fusing sub mains other than fitting an MCCB panel? Basically I have a sub main to a laundry block, and one to a toilet block. There may be a db fitted next to the proposed panel in the future so I need to leave allowance.
I can’t think of any other way than MCCBs or separate switch fuses with a single point main isolator switch which will look awful.
Your options are a panelboard, busbar and switchfuses or distribution fuseboard as far as I know.
Unless you get a custom built bit of switchgear, but that's pretty unlikely for two circuits.
If there is a DB to be fitted next to the panel then you could get a panelboard such as the Schneider powerpact4 which has an extension box available which houses a TPN DB.
Reply to Distribution in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Thanks for the information much appreciated
