Diversity and max load | Page 2 | on ElectriciansForums
Discuss Diversity and max load in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
thats about it but the switchfuse of submain has to me within 3meters of main switch and interlink cable if within 3metres has to carry the maximum submain load.
Hey guys just reading though all your replies to my thread....
I will look at the regs as well, thanks for heads up.
The submain cable will be going on a Isolation, as stated in regs over 3 metre it is needing one.
So basically in a nutshell what you fellas are saying is...
1. An isolation switch for submains the Rating of it just needs to cover the Current Carry Capacity (after factors applied etc etc).
2. The Main/RCD switch rating needs to cover the Max demand of the circuits etc etc.
3. I need to mutiply the florescent lighting wattage by 1.8 then do diversity. I take it this is because of the start up current pulled by the module.
Cheers guys,
Big thanks for all your time...
Reply to Diversity and max load in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
