[/QUOTE]I'll add that when I was serving my time we completed an EICR on a 12 bed guesthouse (with attached 3 bed owners accomodation). The guesthouse was supplied with a standard "100A" domestic supply. The install was spread over 3 or 4 boards to accommodate various extensions/renovations over the years. There was in total 13 electric showers within the property ranging from 7.5 to 10.5kW! No reports of problems from the owners in the 5 years they'd owned the place![/QUOTE]
Hi resu,
I know this is an old thread, but I'm wandering what code you gave the property with 13 electric showers.
The reason I ask is I have been to quote for 7 bed guest house and they have 8 electric showers on one split board CU. supplied by 1 phase. Obviously I would codee C2 for overloading of each of the 63A rcd,s and the 100a rated main switch.
The dilemma I had was the customer asked if the showers are split between 3 boards would it comply. I feel no so would still give a C2 as the main incoming 100A fuse would be overloaded.
There is no visible sign of overheating inside the CU.
I have to make clear I am just at the quote stage and pointed this out to the owner as I was having a quick look to give him an estimate.
I have in the past split 5 existing showers in a guest house and gave it a C3 with a big statement/ risk assessment and advisory attached to eir.
But 8......
Hi resu,
But 8......
