Diy extension lead 2.5mm twin &earth? | Page 4 | on ElectriciansForums
Discuss Diy extension lead 2.5mm twin &earth? in the DIY Electrical Advice area at ElectriciansForums.net
Agreed. Why not just use wet string?
Wet rope is better.... Takes longer to dry out...
No Mate cus you is a fat bloke, there satisfied now :D:oops:
Maybe I could lard myself up and then I will be able to get them on... I'm ignoring all advice in this silly forum that doesn't meet my desire.......
You only need to state I'm fat once mate... Or am I that fat that it needs drumming in... :tearsofjoy::tearsofjoy:
It won't do. It's completely the wrong cable and wholly inappropriate for this application. Non-flexible cable isn't suitable for extension leads. Also it cannot be fitted into plugtops. Also plugtops are not designed to accept anything larger than 1.5mm^2. This is non-compliant with BS1363.
Indeed plugtops have no terminals. Only plugs do.
Its Spring! Time to plant the bulbs - GU10 MR16 GU5.3 G4 and a sprinkling of G9s - I love this time of year.
Yawn!
So, George, what's a plug top? is the the top of the plug? or something completely different?13 amp plug tops - Google pretraga - https://www.google.co.uk/search?q=13+amp+plug+tops&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&dcr=0&ei=94eRWrq5EszHXtmOjMgP
All the plugs/plug tops I have connected up, and that will be many thousands, have 3 terminals L,N, and E have I been connecting these things up all these years? Perhaps if I went into a hardware shop and asked for a plug what would they give me a thing to stick in the sink to stop the water escaping, and how would I connect it up? a bit of chain presumably, as far as I and many other electricians are concerned a plug is summat for the Bath or sink. and a plug top is summat you join wires to make it work. Just saying.
Thanks for all the replies. But why can't this 1.5mm twin and earth be used? as from the socket it will be clipped direct to skirting then the metal back box (secured onto piece of wood) would be screwed direct to the wall just above skirting in the basement the metal faceplate will obviously need earth lead and sheathed. It will never be moved unless being removed all together. Now without all the "buy a lead it's only couple pound"etc remarks can anyone advise me why this is unsafe dangerous etc? Yes I'm bothered saving couple quid and I'm not wasting cash on items that I can make with leftover crap in my lock up. Thanks for any info etc
Well you seem to know best so why ask in the first place?
Yes because Twin and cpc cable, is not designed for use as an extension lead, to be more precise for fixed wiring, although you intend to fix your makeshift dangerous extension lead to the skirting, you will be hard pressed to describe it as fixed wiring.
A plug top is the top or cover of the plug. Pure simple English.
It goes without saying that those websites you Googled are wrong.
All the plugs you have connected up may have 3 terminals (I'm surprised you have never come across 2 pin or multi pin plugs). I doubt if you have ever come across plug tops with terminals.
There are indeed plugs for sinks, and there are plugs for electrical sockets, but any electrician who thinks a plug top is something you join wires to is ignorant.
Is that right? you seem to be calling a lot of Electricians Ignorant, time for the ignore button methinks.
Reply to Diy extension lead 2.5mm twin &earth? in the DIY Electrical Advice area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
Good point, they do look a bit 6mm-ish when you mention it, and that is not going to last long enough for a D63 to trip! It might, on a good day...
