DNO earth | on ElectriciansForums
Discuss DNO earth in the UK Electrical Forum area at ElectriciansForums.net
Hampshire
Hey people,
My friend just bought a flat which has had a solar PV install in the last couple of years and he wanted me to have a quick look (not that I touch PV)
Anyway, I found this:
[ElectriciansForums.net] DNO earth
It looks like the guys have rammed the earth up the sleeve on the incomer? I can't see why they wouldn't of terminated the earth in the cut out?
The whole install is a lash up to be fair.
Probably the incoming cable is split-concentric.
The centre is the line (live) which is obviously insulated, and surrounding it are multiple cores for neutral (insulated) and earth (bare) so when taking those earth wires out to the main earth terminal they have taped or sleeved them, hence it looks that way (and not neat as an extruded PVC earth wire would).
The line and neutral terminate in the cut-out, with the red link in place of the main fuse (which presumably in somewhere in a communal distribution board).
According to this page, the Eland aluminium split concentric is orange:
But I would be a bit surprised to see Al used in a domestic feed.
Reply to DNO earth in the UK Electrical Forum area at ElectriciansForums.net
This is a baffling fault I've been fighting with for a couple of weeks now, so I wondered if another set of eyes will help. I installed an EV...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
