DNO Fine or Jail.
We all say, the fairies came and pull the fuses, so ive been told, Cough Cough, but what is the actual offense for this as say an employer insists on doing this and you do keep reminding him about the errors of there ways, (Do it or you are sacked, Ive got 12 kids to feed so you have to, lol) but who actually gets fined or jail and can the Client report you for this if he or so wishes(now it seems scarey if they dont want to pay up).
This is something I would like to know or maybe directed to a page covering this..
Thanks guys for some sensible answers.
Was looking at this the other night funnily enough. There may be others but here are the two that were relatively straightforward to find. Bear in mind the DNO seals are part of electrical plant provided by the DNO.
Electricity Act 1989 Schedule 6 para.6
A person who intentionally or by culpable negligence damages or allows to be damaged—
(a)any electric line or electrical plant provided by an electricity distributor; or
(b)any electricity meter provided by an electricity supplier,
shall be liable on summary conviction to a fine not exceeding level 3 on the standard scale.
Electricity Safety Quality and Continuity Regulations 2002 para.25
No person shall make or alter a connection from a distributor’s network to a consumer’s installation, a street electrical fixture or to another distributor’s network without that distributor’s consent, unless such consent has been unreasonably withheld.
About 10 years ago I was speaking with some one from nedl after a tenant literally jumped the meter with a set of jump leads and a towel wrapped round the handle to insulate. He said that if they did prosecute it's a £2k fine which is a personal fine. All the sparks stood their ground and refused to do it so it wasn't too bad.
No Jail but, Could easilly be both Spark and his / her employer
Level on the scale.. .. Amount of fine
1 ................................ £200
2 ............................. .. £500
3 ............................ £1,000
4 ............................. £2,500
5 ............................. £5,000]
I never know how those seals seem to vanish. But if you want to re seal after use £25 is a bargin: http://pages.ebay.com/link/?nav=item.view&id=350849458733
Sorry but in real world just not going to happen especially if you reseal it. Been down that road with eon
For a prosecution to happen, unless it's a private prosecution (rare) then the CPS will only take it to court if it's deemed in the public interest. Is it in the public interest to prosecute an electrician who was acting in order to work safely, has stolen no electricity, quite likely had to see the fuse in order to complete her standard IET-approved paperwork, and has damaged nothing more than a pair of wire seals? Doesn't sound like it to me. Then if it goes to court the onus is on the prosecution to prove beyond reasonable doubt that you committed the offence (you have to prove nothing). It's probably going to be difficult for them to do that unless you've incriminated yourself. As we all know you are at no point obliged to say anything. Therefore it might be considered prudent to simply say (and write) nothing to indicate that you have pulled a DNO fuse. How you recorded on your EIC / EICR what the DNO fuse was if it's neither labelled nor visible is a tricky one. :)
If you were SURE that you could back the reasons for your actions,and demonstrate knowledge in the subject,i think the likelihood of a successful prosecution would be slim. I can think of many situations,in work and life,where you require permission,certification and licencing,where if you did so without,you would be fine. An easy one is First Aid. If the situation demanded it,and you were capable,it is possible that serious medical procedure,even surgery,could be administered. Now,if the recipient lived or died,would you be prosecuted? ...Possible,but not likely. Going back to the "sacred fuse pull" argument,i think the fact that lots of people are doing it,with lots of DNO's knowing it,yet with no identified (to my limited knowledge) prosecutions,tells us the story.....now stop worrying about this and concentrate on something more important,like why there are less Bumble-bees...
moose,
telectrix,
