AJB Temple
Trying to post a thread with normal terms like "switch" and get error message that I can only post three tags and 5 tags in total. I don't understand what I am doing wrong.
Thanks. Adrian
Thanks. Adrian
Discuss DNO question about incoming in the UK Electrical Forum area at ElectriciansForums.net
rcd main switch?This is what I was trying to post a minute ago. It as forced me to do it as a reply to myself. Presently we have a 100 amp supply with conventional modern meter, compliant tails to the consumer unit (tails replaced by DNO I believe in 2018 when new main CU was installed by a third party. Annoyingly there is no master isolator switch. On the other hand there are no seals presently on the main incoming fuse either.
I am considering getting a smart meter to monitor the consumption of different areas of the house and I am wondering if the supplier will combine this with the fitting of an isolator if we request it. Any thoughts on how best to get this done all in one go?
what between the meter and the cu ,why should there be one .Annoyingly there is no master isolator switch
Ring up the DNO ask for one, if not ring a tooth fairy spark they could fit one.isolator - yes I want one between main fuse and the meter. I want to be able to fully isolate everything as the area where the main CU etc is, needs some building remedial work. It's a mess.
Reply to DNO question about incoming in the UK Electrical Forum area at ElectriciansForums.net
