SSE install their own REC 4 isolator after the service cut out / polyphase meter on split phase. Two ways are used as L1 and L2, L3 is blanked off and the neutral is a solid non switched link. They will fit a "normal" REC 4 but will not be held responsible for any damage caused to the system if the neutral breaks first or makes last - their view is that the consequencies however small of getting momentary - or worse - 460V to earth (in a 230-0-230 tncs system) is too great to risk. I had a Hager 63A type D 3way mcb to isolate the split phase supply from a wind turbine i.e. L1, L2, neutral but since that "discussion" I have taken the neutral to a common neutral bus connection inside the mcb enclosure.
Thank you for a positive reply ! It is my first post and in my excitement to find something that I actually had knowledge of I completely missed the date of the OP............will try harder next time :blush2:
Ha Ha! Thank you for your (belated) interest, gentlemen. Yes, all sorted long ago: I used the correct Double Pole MCB. No problem to source, it was just that my usual supplier, TLC, did not list them.
Welcome, Bill - if you have a split phase install at home, I'm delighted to find someone else on here who might actually know what it is! Are you saying you NEVER switch neutrals?
Thank you for the welcome - I decided to err on the side of caution in the belief that the SSE may actually know what they are talking about in this instance - especially as this is a common upgrade in North East Scotland and they do a lot more split phase installs than I do (and they gave me a nice REC4) so for split phase systems I don't switch neutrals - so far it has been the correct decision !! What was also vaguely interesting was that I checked with Hager Technical regarding the mcb I fitted and they told me that Hager mcb neutrals do indeed break last, make first.........but how can you be sure without 100% QA/QC ? we are talking milliseconds...............
Sorry Bill, just lately we’ve had lots of resurrected threads and they tend to confuse things.
Split phase supplies can be a bit of a minefield, I got used to them working in quarries 40 odd years back.
There has been a resent thread about them, which is a bit weird in the way the DNO have done it.
tt system on a farm what advice would members give on fitting 300ma rcds on a split phase supply looking at pv install so type a rcd required.regards
0° centre tapped is normal. 180° will give 0V phase to phase and the neutral would have to be 2X phase CSA conductor.
It could be a Scott or LeBlank 90° connection
So what voltage does the PV system work on?
single phase inverters 3.6kw tl fitting two each protected by 100ma rcd type A, farm install.treating the install as two seperate installs g83 settings so 240v nom 1%vd design swa cable regards
If you are going to be feeding in to the network then you could run in to problems with 230V.
You would effectively be feeding in to only ½ of the transformer winding, it won’t be happy, neither will the DNO!
I have sent you a PM
Mark42
Patron
UK
United Kingdom
Other
Do 2-phase (split phase) lines ALWAYS need to be switched together?
Electrician Talk | All Countries
Mark42,
Knobhead,
