Do I need an inline fuse between my alternator and battery isolator? | on ElectriciansForums
Discuss Do I need an inline fuse between my alternator and battery isolator? in the DIY Electrical Advice area at ElectriciansForums.net
Colorado
I purchased a 95 amp battery isolator and my alternator pushes 95 amps but I'm assuming that it may spike above that occasionally. Should I put a fuse between the two? I am only aware of 100 amp maxi fuses would that save the isolator for damage or do I need to purchase a battery isolator rated for a higher amperage?
Alternator output current is self-limiting and will not exceed its spec by much of a margin for long, and hence is very unlikely to damage the battery isolator. A 95A alternator is unlikely even to be able to blow a 100A fuse, which might take hours to react at 130A.
What the fuse might offer is a degree of protection against wiring burnout if the battery or main cables on one side of the isolator become short-circuited, and the battery on the other side dumps a heavy current through it. It's sufficiently unlikely though, that not many installers fit a fuse in that line. Also, the resistance should be kept as low as possible to ensure that the secondary battery receives full charging voltage even when there is load present.
Reply to Do I need an inline fuse between my alternator and battery isolator? in the DIY Electrical Advice area at ElectriciansForums.net
Don’t bother, 3 to 5 min of microwaving will take a car battery from full to empty. even if you can start your van afterwards, the duty cycle will...
    • Optimistic
Couple of issues facing car owners is "sleep drain" when the car has a new multi function HU that sings and dances .Those buggers kill a battery...
