Hi all,
I'm installing a temporary supply to a modular kitchen and need to bring over a new 3PN supply for a new temp consumer unit located externally in a suitable IP enclosure.
The cabin is connected via 63a plug, do I need a rotary isolator to control my 63a socket if the said socket is literally next to the CCU? Can the MCB be used as local means of isolation?
I would normally install a isolator but as this supply is only in situ for 3 months it seems a waste of materials (which will most likely be binned at the end) and also reduces the space required within the enclosure.
