Do I need to certify equipotenital bonding to new gas pipe | Page 2 | on ElectriciansForums
Discuss Do I need to certify equipotenital bonding to new gas pipe in the UK Electrical Forum area at ElectriciansForums.net
Kirkheaton
I have a customer who has just failed his gas safety check as he has no bonding to gas, job is straight forward enough. Just wondering what paperwork would be needed for this? If any?
There is too much paperwork bolted on to this job without giving ideas to the form makers
A extra full chapter on certification of bonding services for the
18th edition
Accompanied of course by a guide which includes a shortened version(on- site bonding. guidance note 631) and a new form specifically for bonding of those services.
Needless to say a new coloured regs book will be required
Part 1 of the form will be for Gas
2 O
il
3 Water
4 Structure
Supplementary bonding would entail the completion of all 4 parts
It will of course need the usual 3 signatures, pads of 200 will be available at only a small cost
I forgot to mention that courses will now become available with a level 3 city and guilds,it is expected that all electricians eventually hold this qualification
Posted a "funny" but in actual fact, what's even funnier Des is probably correct.
Des is usually correct when he's not out chasing sheep. think his recent lack of posts is due to trying to get his head round these gender neutral sheep. there's a supplier in Swansea that does gender neutral wellies. fit either foot without discrimination.
That must be Boots in High street
I know that the regs state that the bonding clamp must be fixed within 600mm of it entering the building and before branches/tees etc...but I looked at a job today with no gas or water bonding and was built in 1988.
It was noted on a MWC issued by a guy belonging to no CPS 4 years ago, but apparently must have been temporarily rectified when an NICEIC guy issued an EIC for some work 3 years ago.
My question is that it will be a pig to get to where it enters the building but would be very simple to bond in the external meter cupboard about next to the external electric meter cupboard. Would this be seen as acceptable as it is an improvement on existing and would be classed as a limitation imposed by the customer.
If it was built in 1988, are the services plastic? Perhaps that's why they are not bonding. Not trying to be smug, as I've only recently been introduced to the bonding metal internals after plastic service, scenario.
Reply to Do I need to certify equipotenital bonding to new gas pipe in the UK Electrical Forum area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
