Do I trust this Electrician | Page 2 | on ElectriciansForums
Discuss Do I trust this Electrician in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Guys, a little bit of clarification here please, I have always tied the Smoke alarms into the lighting, Primary reason being to stop people isolating them, Am i wrong???
This has been argued to death on this website and no definative answer was agreed, I was always lead to believe that they should share a lighting circuit so as not to be turned off when that beeping starts but others disagree
This thread is eleven years old and current requirements for the connection of Part 6 is clear in BS5839:6 and Approved Doc B which mimics BS5839. A lighting circuit or dedicated circuit are both acceptable, the requirement for isolation if on a lighting circuit is no longer required.
Reply to Do I trust this Electrician in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
I guess my last post was even less direct than intended.
nicebutdim
N
