Do you charge for quotes? | on ElectriciansForums
Discuss Do you charge for quotes? in the UK Electrical Forum area at ElectriciansForums.net
spud1
Somerset
Evening Sparkies.
Does anyone charge their clients for site visits/consultations and/or quote writing?
Have a look at this thread below mate.
I don't directly charge for quotes, I build that cost in to the quote.
Site visits and consultations depend entirely on the circumstances.
If I request a site visit for my benefit then I don't charge. If a customer requests a site visit which is outside of what would be normal for the job then I would explain that it is chargeable and charge for it.
I'm far more lenient with regular customers on this than I am with one-off customers.
If its a new client and you think they are just "fishing around" .If they want a very detailed quote then YES charge . Chances are they think you are the best . and will use your quote as a "project management guide " to find someone a lot cheaper and to do what you have quoted etc etc .
Yeah I have had that, you spend hours working out calculations etc, talking to NAPIT, talking to the DNO etc and then they take your quote and show it to someone else minus the amount and ask them to quote for the same...
The problem is people don't appreciate how long it can take to do a quote, I much prefer giving a rate per hour plus materials, I then give an estimate of how long I think it will take but its literally just that an estimate...
There are a couple of charities I have had to do quotes for and I don't mind losing a bit on those cause they are charities but I understand why trying to get someone to quote is so difficult.
For an itemised quote I charge - it cuts the wheat from the chaff, for any other job - I charge - its just that its built into the quote without stating it. If there is a risk that the details are specific enough to be used by another electrician to beat your quote - I make sure I 'vageuify' them somewhat - the trick is to leave specifics out, but outline what the client wants. For example - a rewire will start out life as a vague quote, then have additional levels of detail specificity added later so that any other spark would have to travel the path I have to get their quote together while the bidding is going on.
Reply to Do you charge for quotes? in the UK Electrical Forum area at ElectriciansForums.net
A day for sure. I recently installed an Anderson with dedicated CU. The run was a fair bit worse as I had to drop a section of ceiling and chop...
We have some very old delmatic lighting control modules that have pcb and relays for switching they have mostly burnt out. I need to change them...
