Do you have to become Part P registered to certify work? | on ElectriciansForums
Discuss Do you have to become Part P registered to certify work? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Norwich
Hi
I was wondering if someone could offer some advice?
The business is doing a lot of kitchen and bathrooms and every so often they need a new cooker circuit or extractor fan, FCU for a standalone oven that sort of thing. At present I wire it in test it and then a lad I know comes and test it and signs it off for me but this has become a pain as I have to wait for him and his work load is increasing as is mine.
I've spoken to NAPIT and they have said I can become Part P registered however I have no intention of doing full rewires or changing CU and it seems like a lot of cost and work for something simple like adding a cooker or oven to a CU. If the CU needed upgrading I'd sub it out to an electrician as I just don't have time to do that sort of thing with multiple projects on the go.
Is this really the only way to be able to certify a new circuit apart from BRegs? NAPIT were going on about 3 phase and commercial stuff and that I could change CU and do rewires and I just could not get it through to them that is not what my business does.
Do all kitchen & bathroom fitters become Part P to wire in a circuit?
Many thanks
Hi
Many thanks
Oh my
Upvote 0
The shortest and no worry way is to use an electrician who is in a CPS scheme. The complications legally and otherwise are too much to go into but trust me when I say it is better to do this. In this way you will avoid any liability for defective electrical work. It may be a pain but it is better to do it properly in the first place than deal with the fallout if it goes wrong. There is lot more then just part p for installing a circuit, not to mention the expensive test gear you need apart from a level 3 electrical qualification.
Upvote 0
Does your insurance cover you for electrical work?
Upvote 0
as said above. ^^^^^^.you can certify your work, no problem, but you can't notify it unless you are in a scam such as napit. niceic, elecsa etc. part pee is a joke. a Electrical Trainee wetbehind the ears with little or no practical experience can join a scam and be registered with part pee. but a qualified spark with 20+ years on the tools is penalised for not wanting to have to pay to work.
Upvote 0
Hi
Many thanks
Sounds like you have been bodging and old mate down the pub is taking 100 for the cert each time o_O
Upvote 0
10 out of 10 for asking the question .... there are many kitchen and bathroom fitters around who don't give a monkeys about any building regs ..... So this means, especially in kitchens that Kev the botch artist leaves a trail of mess and when people are spending vast amounts on their refits, not doing the electrics properly is such a poor approach
So if you have the competence, the qualifications and the necessary test equipment etc you should consider it.
Stroma only charge £240 + VAT per year - so not too much.
BUT why don't you get a decent spark involved so that when you need them, they do ALL the electrics .......... anyone asking me to sign off "a n others" work don't get a yes from me.
Upvote 0
I have a Megger MFT1721 that I bought when I did my electrical training courses
Upvote 0
This day and age of accountability and blame when the proverbial hits the fan its a risk putting your name to anything... when all this tower fire fallout happens accountability will go in to overkill with record keeping and risk assessments aplenty
Upvote 0
Why bodging it? I have the qualifications and experience I calculate the diversity I choose the right cables I comply to the regs, I use the correct tables for the appropriate way it is mounted reducing the amps for the cables for the way it is fitted/depth/insulation, I check continuity, insulation resistance. This is all then rechecked and more when my mate signs it off. Is that bodging it?
Upvote 0
Thanks did not think of Stroma. The problem is my mate would do the work but chasing one cable for a cooker when it takes 1/2 an hour to do holds up the tiler who is waiting for the plasterer to finish, who is waiting for a sparkie to turn up and chase and wire one circuit.
When you have multiple jobs on the go its not always practical to have a subcontractor as I did have a spark but if he was booked in to do a quick circuit and got a full days work it would fall by the wayside and hold up my projects and with subbies waiting to get started it did not work well.
Guess the way forward is to get registered
Thanks to everyone for the advice :)
Upvote 0
Sorry did not realise you had qualies etc. So yeh get part P and BS7671 when the 18th comes out. Then pay for scam scheme I mean. Then you are good to go. I am with Stroma they are thorough on the assesment. If you decide to bite the bullet get back to us for info on the assessment. Good luck.
Upvote 0
I worked in the offshore industry for over 20 years and everything is RA, TBT, you can't fart without someone signing it off. I ran a team of 30 guys and they would be pressure testing at 4000bar running gear off 100kVA generators. Every morning would be a TBT go through what was happening and it was strict, recorded and regimented.
When I left and started up my own business I could not believe how relaxed everything was in the domestic world. It was a real eye opener! But no trade seemed to accept any responsibility for the work they under took, turn up have a cuppa, mobile, smoke, cuppa and then a moan about the weather! All I can say is after getting through loads of subcontractors I have a good bunch and they work how I want them to. Might cost me more then the going rate but I know they are doing it right.
As part of a trusted trader scheme I have to keep the records of each job and do my own RA for any out of the ordinary tasks again time consuming but its about keeping the guys safe and covering your a55.
Upvote 0
I've just emailed them I've done Part P couple of years ago but will need 2391 and I think the 18th is July 2018? Cheers for info will drop you a line when I've had a chat with them about the assessment.
Upvote 0
Reply to Do you have to become Part P registered to certify work? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Isn't it just a little sad that it should cost sooooooo much to LOG a few jobs to BC.... O where did it all go very wrong ? Signed Man in tights...
It applies to commercial if it shares the same supply as a dwelling.
Electrical Courses
