Do you really really need more | on ElectriciansForums
Discuss Do you really really need more in the Electrical Tools and Products area at ElectriciansForums.net
Squid
screwdrivers, it seems the answer to that question is yep you do......... this is just "some" of the ones I have,
[ElectriciansForums.net] Do you really really need more
orderred these........
Its a good set, my reservations with those is that should you scrog a blade (you know, if you lend a plumber your #2 POZI and he uses it on a Philips screw) do you need to buy a new set.
Unless they do spare replacement blades?
Wouldn't loan mine to anyone, least of all a plumber!!!!!!!!!!!!!
i have the Wiha slim. set. spare blades are available, but expensive. just ordered a replacement 4.0mm slotted bit £7.49. should think the Wera ones are available at similar cost.
I went for this set as it comes with two handles so hopefully less blade swapping.
funny. i got 2handlesalso.lost one at a spar shop. bought another to replace it. 2 weeks later the "lost" one was found under a display unit. on'y a 1" gap but the bugger had managed to roll under.
I bought a couple of spare blades at Elex/Toolfair last year from the Wera stand, IIRC they were about £6 each.
Hopefully you where either shopping or working and not there at 02:00 breaking in..........
What are you insinuating SWD???????????
he's racially abusing this Scouser. as if I'd break into a Spar at 2.00 a.m. nothing in the till or safe at that time. they'll have banked it all. :confused::confused::confused:.
hey @SWD , not only do you have an impressive collection of screwdrivers, but I also see 1,2,3,4...5 marking devices.
That'll be a sharpie pen, another marker pen... 2 pencils with rubbers and a carpenters pencil. You only need one. The perfectly shaped one that fits your ear. (in the groove between ear and head.... not in the earhole!)
Reply to Do you really really need more in the Electrical Tools and Products area at ElectriciansForums.net
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
I’ve found a Megger one for £23 from Screwfix. I’ll get that.
