Dodgy electrics in many homes >:( | Page 2 | on ElectriciansForums
Discuss Dodgy electrics in many homes >:( in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
General Technical FAQ's
This recommends that the device be at least 300mm away from the sink which it is. But I cannot believe that this is good practice in any way. If you are in a situation where you have wet hands (or in splashing distance), there should be no out let or mains switch unless isolated via a transformer to a lower voltage. The only exception I can think of is a switch that has is all plastic and uses a rubber membrane to seal the internal electrics.
So the extent of your gripes about dodgy electrics are fatigued connectors and plate switches in bathrooms ?
In the words of Bachman Turner Overdrive, you ain't seen nuthin' yet.
Oh god is there worse to come?
Mind you, I have seen the following as well:
Piece of metal instead of fuse
Scissors in earth to connect American plug
Bare conductors with no insulation close to each other
80mA RCD in a TT system
Downstairs light was not connected to down stairs light circuit. Dad got shocked :/
I know that people here will have seen far worse but it still upsets me to know this happens frequently.
Not sure how he ended in ther.
[ElectriciansForums.net] Dodgy electrics in many homes >:(
This is down to poor labelling and documentation, not in the wiring installation. Many houses have lighting on multiple floors on the same circuit. Hence the need to assume that a wire or fitting is live until proved otherwise.
What's wrong with an 80mA RCD in a TT system, or any system for that matter? (Not that 80mA RCDs are even available as a standard item in this country)
Having lighting circuits mixed so that each floor of a house has lights on multiple circuits is actually a very good idea as it allows a degree of light to remain from nearby rooms if an MCB trips and could help prevent accidents occurring.
Hi Everyone,
I have noticed that in the past three houses that I have lived in there are always dodgy electrics.
In my bedroom there was a humming sound that always came from the ceiling rose but until now I assumed it was the dimmer switch. So today I changed the switch to a standard one (on off), but the buzzing was still there.
So at this point I knew "Damn, that has to be an electrical arc :O", so I took out the ceiling rose and to my disgust found the worse set of wiring skills ever. The ceiling rose does not have any terminal blocks built in which is why I did not mind finding loose terminal blocks. But one of these connectors was a transparent piece of plastic that has mini grips to connect multiple wires to a common bus. I took that out, cleaned all the connections and no more buzzing. I believe that the plastic connector was either old or the mechanical grips (no screws, just the force of the bent metal), was not making a solid contact so add some erosion and oxide and you have the perfect spark generator.
The previous house had wires not even on the correct circuits and the consumer units was useless.
Sometimes I just think to myself "ARRGGHH". How can this work pass at all? Is it being done by DIY people? Are there electricians who do work this badly? Its obvious to me that there are people who should just not be allowed near electrics.
Anyone care to share their disappointing stories?
The connector you described sounds like it could be something similar to a wago push fit connector. It is far more likely that the poor connection resulted from corroded/tarnished conductors being inserted into the connector rather than the connection degrading. These connectors have gone through rigorous testing and approvals.
Do you have any pictures of the offending articles so that we can get a better idea of what you are talking about? If it is a failure in a wago type connector then I, and probably many members, will be very interested to see this as these connectors are becoming widely used now.
Dont have a picture but here is what it looks like (exactly as you described):
http://www.mallinson-electrical.com...eab33525d08d6e5fb8d27136e95/2/2/2273205_1.jpg
Chances are these push connectors dont give you the same mechanical contact strength as most other connectors do. Dont think I will ever be using this type of connector personally.
As above, these connectors are widespread and proven to be effective and safe. They have been used across Europe for decades as far as I know, I recall them being incorporated into light fittings in the UK for at least 15 years, and they are now becoming the norm in the UK.
A badly prepared cable conductor is more than likely the cause of the problem as Davesparks said.
Reply to Dodgy electrics in many homes >:( in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
What type of car have you got/ordered ? I use a portable charger, can charge as low as 6 amps and the car's maximum is 26 amps. I have a number of...
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
