Dodgy meter move, how to fix? | Page 2 | on ElectriciansForums
Discuss Dodgy meter move, how to fix? in the UK Electrical Forum area at ElectriciansForums.net
sw600
london
Hi all
I have just bought an old house. At some point in the past someone moved the meter and consumer unit from their original position next to the incoming head (?) to about 8m away, using pyro cable. There is also a 60A fuse next to the meter. I don't know what size the fuse in the head is yet, as this is handily boxed in behind some plywood. I assume this move wasn't entirely legal.
Now I need to uprate everything to 100A for a new shower, but UK Power Networks have washed their hands of this by claiming that they can't uprate the cabling between their head and the other fuse/meter/CU, and that I should get an electrician to do it, before they can fit a 100A fuse. I called a reputable electrician and he said he wouldn't touch it. He gave me the number for a less reputable electrician who will do it, but I want to ensure that he is doing something safe, if still not entirely legal.
What should I do here? Should UKPN be doing this instead? Or even my electricity supplier's engineer?
thanks
Dan
Also does there need to be some sort of earth connection from the head to the consumer unit (Currently I think the metal skin of the pyro cable does that?)
I understand enough about home electrics to change sockets or fittings but I have no clue about earthing or whether it's TN-C or whatever.
Sw600
The DNO owns the cable into the cut out from the road and the cut out. In this case uk power networks. The supplier owns the tails from the cut out and the meter. The DNO is fully authorised to cut the seals on the meter and even move the meter (although some DNO's won't move smart meters) so if you were to get your electrician to run new tails from your consumer unit to next to the cut out. You could request a meter move pack from your DNO, and have your electrician there at the same time. The DNO can move the meter and connect the new tails in at the meter end. The electrician at the consumer unit end.
The supplier is fully authorised to cut the seals on the meter and the cut out in order to remove the cut out fuse to make the meter dead to replace it for a smart one or move it or fit an iso switch etc. However due to the smart meter rush many meter men have very little experience and will often be worried about the older cut outs. Neither will touch the old pyro. The thing is when privatisation occurred the suppliers took on the metering and the problem that goes with it. But some suppliers seem to have very few people "on the tools". Where as the DNO's control, maintain and build the network from 132kv down to the 230v in your house. 275kv and 400kv belongs to national grid.
Some pictures would be good, is the cut out metal clad or plastic?
I have in the past run 25mm tails from the cut out to a KMF mounted at the cut out then run split concentric to henley blocks and from there tails to the meter. Fit a double pole isolator after the meter for future isolation purposes. DNOs and MOPs like to have it all close together as once their responsibility ends at the meter load tails where as with a sub main and remote meter position they normally have responsibility for the sub main.
There are still large amounts of 60A cut outs in use, they simply cannot anymore be upgraded by firstly measuring the ZE and if acceptable then fitting a higher current rated fuse. A new cut out may be required and possibly upgrading of the service cable.
Reply to Dodgy meter move, how to fix? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
