P
pablo4321
Hi need some advice, changed a db today everything was fine until testing ring final,there was no continuity on r1 r2 rn so no ring now but the 1 leg is supplying power to all the sockets in the house so basically a radial, it was on a 30 amp old fuse so changed to a 20 amp mcb did a i/r test which showing 0.00 on all conductors this on the rcd side trips also checked R1/R2 no continuity did a wander lead test from this leg on the earth at db disconnected to a couple sockets no continuity to earth but when i touched the neutral there was, any ideas what is going on regards paul
