dodgy ring final | Page 2 | on ElectriciansForums
Discuss dodgy ring final in the Talk Electrician area at ElectriciansForums.net
thanks alanl going back tomorrow to have a look just put sockets on non rcd for tonight as was getting late
unbelieveable!!!
- - - Updated - - -
UNBELIEVEABLE!!!
what? How about just using that expensive bit of kit you're supposed to use to see if a future rcd will hold! E.g a multifunction or an ir tester?
Haha I can just imagine a make shift RCD floating around somewhere on the tails, and when it trips turning to the client and saying, sorry I can't change your board I'll leave it.
Reply to dodgy ring final in the Talk Electrician area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
Yep! Edit button was disabled by the time I seen it. Hopefully the 15m/15m clarified what I intended 😀
2 3
