Dodgy trade pictures for your amusement! - 1 Million Views! | Page 239 | on ElectriciansForums
Darkwood
It was indeed ABHORRENT!
Some might argue that as an apostrophe denotes something missing (as opposed to the possessive, which it also does, in context) then pic's is simply an abbreviation of "picTUREs". However, IMHO, in current usage, the abbreviation should be pics, ie plural of "pic". The language evolves...
My favourite example,which has variations, is "fo'c's'le".
Why is "abbreviation" such a long word?
Like 'bus' - this was originally 'omnibus' and later abbreviated to 'bus. But nobody uses the apostrophe now. As you say, language evolves.
I knew somebody would suggest that as a possible correct usage. But I concur that "pics" is a plural form of "pic".
It was abhorrently aberrant!
I wondered why N & L3 IR test on generator incoming connections was around 400M but everything else is above 1G. Went to connect a temporary lead to the external box to energize for rest of tests and discovered it was surprisingly damp. This shows the roof of the box!
Not sure where the water is getting in, but trying to at least have a way for it to get out now.
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
damp air getting in and condensing.
Thing is the similar box for the mains incoming supply is completely dry. Also both boxes have some venting in to the main building via the 50mm conduit hole you see the cables going through (ends up in 100x100m trunking, etc) so they are not really sealed.
It is possible it is fixing screws that are not completely sealed, or the door hinges (they bolt on from outside the door gasket). Also the door lip had a slight dent with the seamed are welded but the gasket seem soft enough to compress in to that.
Will see if i can get a pressure washer on site again and strategically soak it to find out!
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
