View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Now i'm confused. I've never seen an arbour that will let you attach two hole saws at the same time?
Some do, some don’t. Just depends on the length of the threaded part.
As per post #5904, Starret make something specifically for this, it's called an Oops Arbour. CK also do one. It replaces the pilot bit and means you enlarge a hole by using the original size holesaw as the pilot. Best use I've found for it is changing from the old spring downlights which are 64mm hole to the more modern versions which are anything from 70mm hole and up.
Many ways to do this two as suggested by BrianMoooore above, used both methods, never needed a special arbor to do it, most standard arbours will take two hole saws.
No need for a fancy arbor in this instance, but holesaws aren't used exclusively to cut holes in plasterboard and not all arbors have sufficient thread to accommodate two cutters.
As an Amazon Associate we earn from qualifying purchases.
I can't see how you can easily start a hole in the centre of a joist, as the inner hole saw protrudes too much. ?
I wouldn't use it in those circumstance, unless the ceiling was of sufficient depth to strart the new hole without cutting into the joist.
To my mind their real value is enlarging holes in sheet metal.
Their real value is enlarging holes in plasterboard for upgraded downlighter's and that is what everyone else is posting about.
In my limited experiance the problem are holes that are too big (e.g. old R80 lamp holders) so you can fit smaller LED downlights without getting extra covers, and even those sometimes won't hid the damage of getting the original out if crusted in paint, etc. :(
These are a good option for up to 100mm:
Cut a hole in a piece of plywood, throw away the circular piece you cut out, then hold the plywood against the ceiling, and use the hole as a guide for the hole saw.
It was related to cutting a hole across a joist, a hole saw is difficult to start the cut without some sort of pilot.
Second quote should be first!
This is what I usually do too, where lifting boards in the room above isn't possible/feasible. I find the joists with a magnet, measure 120mm to the side and cut the hole centred there. I cut them all so I can see any cables/pipes, then drill the joists using a dewalt 90deg attachment for the drill.
I'm going to buy a 5 or 6" holesaw for it, as while 4" works, it is just a little on the tight side as you need to get your hand in to apply pressure as you drill the joist.
If you replace the correct p-board circle to it's respective hole, in the correct orientation (mark before cutting), they go back in perfectly. Easifill and then sand, no need for reskimming!
In my experience they never fit perfectly you have to peel at least one layer of the backing off the plaster board otherwise it's proud, ideally you want the infill paper thin below the surface makes it a doddle to skim over.
Orientation of the infill shouldn't matter as they should all be the same, not that it would matter with such small gap tolerances that's going to be filled anyway.
I'm of course assuming that you baton across the hole and screw the infill into that ? If so, then either side of the baton has to be screwed through the ceiling into the baton either side of the hole.
Notching the joist from below is far easier and much quicker, with far less damage to the ceiling.
If using 1mm then the notch is hardly anything.
Drilling the joist is the better job, but far more work.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
