View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Whoever set out those tiles needs to be shot, above the window is near exact three tiles high and there are different cuts on either side, easiest thing in the world to make the niche the same height, Oh and the socket and pendant light.
Agreed, the lower bay tile rows don't even align with the reveals or walls. The floor is clearly uneven so instead of just adjusting the skirting tile cuts they have adjusted the first row of the tapered edged tiles also in places so its a lash up to say the least. Obviously the builder has done all the works himself to save a few bob and as usual, as you often find with many builders the finer details are very rough!
I agree setting out this correctly would have made all the difference to the finish. To be fair though looking at the picture the walls, ceiling and floor look very uneven so it may not have been possible to work in the 3 full tiles as you suggested. This though is no excuse for the lack of thought, poor design and very bad workmanship!!
What's the betting that the metal socket face plate is not bonded back 😜
if the single core cable has a layer of insulation on it underneath the heat resistant sleeve, then presumably it is a double insulated cable?
sorry, i misunderstood, i presumed that there was a cover to clip over them that was not in the picture.
Quite Simpley it doesn't comply with the reg's in my opinion and because of that you should not install them.
Remember, If the place burns down or someone is injured, It is the installer (YOU) that they come after.
Financially you will probably be ok as your insurance company will probably settle the bill if you can show that the installation was done to approved standards of the time.
Hmmm, even back to the 16th edition, i remember that single insulated cables had to be enclosed to protect from accidental damage, so you might be on a sticky wicket there.
insurance may decline payment due to the fact you have been negligent.
however, you have followed the manufacturers instructions ( I presume you have read them and followed them)
so you could pass on the liability to the manufacturer if they have sold you something unsuitable for the environment that it is designed to be installed in.
NOT a position I would like to be in.
bottom line is just use a better designed light fitting, if you think it looks unsafe, don't wire it up!!!
I won't fit those ones. I looked into this a little once. The instruction manual for a Knightsbridge RDB1 refers to BS7671 and includes the step "replace terminal cover". Quite simply, there isn't one! It looks as though it is designed to have one but all you get is this:
They shouldn't be allowed to be sold in the UK IMHO.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
