View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Got a call out to a cooker tripping the RCD every time the oven is switched on. But the time taken would vary. Suspected a failing element.
So went and had a look, tested the element. It registered 25.9ohms so about right for the size of the oven.
Checked all the wiring and took the bulb out to check that as seen issues with those before.
Noticed how the consumer unit was oddly set up but will get to that shortly.
So next tested the RCD.
Trip was fine at 38.6ms.
Ramp test was 19mA which is a little sensitive but above the 15mA minimum.
So next I put my clamp meter on the connections in the back of the oven. It was leaking around 3-4mA until the temp is set. Once the temp is set the leakage then climbs to around 13-14ma and fluctuates between 5-14mA (before the RCD trips).
So looking at the board I can hazard a guess that because they have stuck all the high power circuits on one RCD and all the lights on the other. We have got a case of accumulative leakage tripping the RCD as when the other circuits are off and just the oven is on. The RCD stays on.
Whilst there I noticed the wiring for the outside light. But another electrician apparently said this is ok as it’s out of reach. 🤔
I would check for reversed polarity at the oven, in case it is the neutral that is being switched off so higher leakage once cycling.
Oh FFS!
That is a good advert for why T&E is not a suitable outside choice. Even if out of reach, which is a load of balls, then once it leaks you risk the lights on RCD going off mid winter.
Peeves me when they go to the expense of fitting a spd, but then skimp on a split load board.
I would also be looking at that oven again as that leakage is way too high, Should be around 1 mA or 1 mA/kW of rated power
RCD with a rated operating current of 30 mA, the maximum leakage current is 9 mA
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
