View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Call out this morning for an elderly couple as they had no power due to the RCD tripping all the time. It also caused a flood due to the toilet pump not working and overflowing. Electric had been off all night it seems.
So diverted from the job I was going to and went to sort the problem. After a bit of testing and fault finding I discovered this. All done by an ‘electrician’. 🤦🏼‍♂️
One of the diodes in the light had blown causing the fault. Maybe due to the fact it could pull 32a if it wanted to!
Been to look at a job this evening on the way home. I do love rich folk with farms and stately homes.
‘We need the sheds connecting back up. There’s a board etc in there which is fine. Just need the power back in there’
Here is said board which is apparently fine… 🤨 The T&E is the old supply cable. And the yeehaw 🤠 glanded armour is supply to another shed. 😂
Called out to a boiler not working and keeps shutting off. Plumber blamed the boiler, Manufacturer sent an engineer who said it’s wired wrongly. Plumber said his spark has wired it properly and the property has obviously got dodgy wiring.
I’ll let you draw your own conclusions and yes. That is a 3pole fan isolator. 😂🤦🏼‍♂️
It's normal to fit a 3 pole isolator next to the boiler if the switchfuse is remote from the boiler, this satisfies manufacturers and gas-safe requirements for a local isolator to the boiler.
Obviously it needs to be 3 pole in order to isolate live, neutral and switched live.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
