View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
Call out today as a light switch kept tripping the MCB of the circuit. So after finishing another job I called in on my way home.
I'm surmising that some hamfisted clod has knocked a nail or screw through the cable and it's failed over time. 2 of the 3 conductors had a short when IR testing.
Replaced the 2gang switch then had to go old school to pull a new piece of 3C&E through to make a temp fix. Told them they need to find where the leak is in the property and stop that before I do anything else. The back box has almost disintegrated and the wall and ceiling are damp to touch. So will be back to fit new capping and back box once they have sorted that out.
View attachment 107162View attachment 107160View attachment 107159View attachment 107161
And maybe a MF enclosure, you do get some lovely work though :)
Call out today as the RCD had tripped and wouldn't stay on. Narrowed it down to a circuit supplying a garden pond pump & shed. Traced the circuit and found this switch with a rather wet wall behind. Wish I had recorded the amount of water that came out when I undid the first screw.
Isolated the switch for now and drilled 2 x 4mm holes in the bottom to stop it filling up again and tripping the RCD. Will be back to put it all into a weather proof enclosure and route the cabling better to stop water tracking into it.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
