View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
The 2 plasterers I know do a full skim unless specifically told by the customer otherwise.
The couple of plasterers I know would be clear in telling you where you could stick the job, if there was a suggestion of leaving unfinished surfaces.
Don't think I could sleep at night knowing stuff in the house had been plastered around ?
With a radiator that is conventionally plumbed, with a valve at either end at the bottom, it should be possible to lift it off its brackets, and rotate it 90 degrees onto wooden blocks of the correct height, so that it lies out into the room. All that's required is to loosen the connections slightly and tighten them when its lain over. Leakage should be zero or just a few drops.
that is what i do. rotate , maybe only 45 deg. strap a cable tie or 3 to the wall bracket. paint/paper, whatever, then refix after.
Oh.no wrong again you gotta raise the rad first to tilt
If pipework is clipped properly it's not possible to lift off the brackets. I've tried in my house on the back of this convo and not a one of my 8 rads will lift because the pipework is all clipped down properly. I would have to turn off the water and then completely disconnect the valves to get it off, by which time my floor is soaked.
Someone reckons apparently that properly clipped down pipework is the sign of a rubbish installation though so maybe my installation is just crap.
I the pipes come out of a screeded floor, they should have thick walled insulation around them, and there should be enough compliance in this to allow the to be lifted off.
Sounds like CamoElectric's installation is a retrofitted one, with surface mounted pipework. Even then, there shouldn't be clips so close t the radiator that it's unable to be lifted slightly. Too many clips, and clips in the wrong place, stress the pipework.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
